Click HERE to order or for more information.
VW MK6 Jetta 1.8|2.0T Gen3 ECS Boost Tap & Gauge Kit -
ECS believes your boost gauge should be easy to see, blend with your interior, and provide you with the most accurate readings at all times.
Other methods of acquiring a boost/vacuum signal can lead to skewed data being sent to your ECU, ultimately dropping engine power.
Engineered specifically for the Gen3 engine, we designed our Throttle Body Boost Tap with 2 ports and our Manifold Port Boost Tap with 3 ports, so you have multiple options to provide the strongest manifold signal. You can be certain that all critical data is not affected and your engine's power is not lost.
http://www.ecstuning.com :: Phone: 1.800.924.5172 - Hours:Mon. - Fri. 8:00AM - 11:00PM Sat. 10:00AM - 7:00PM EST :: Email: sales@ecstuning.com & customerservice@ecstuning.com :: Facebook :: YouTube :: Live Chat :: Instagram
